Введение
In this guide, you will learn how to open up the Uniden Guardian G955, unplug the speaker from the motherboard, and then replace the speaker in about 5 minutes.
Выберете то, что вам нужно
Using a metal spudger, open the monitor from the corner. Slowly slide the spudger around the case to prop open the case.
Locate the circular speaker in one of the corners of the device. To release the speaker, pinch the metal fastener together and lift it off of the speaker.
Follow the speaker towards the input on the motherboard. Pull it from the motherboard horizontally for it to loosen easier.
Using an angled ESD tweezer, pull back on the black clamp with one hand while lifting the wires with the other hand.
Carefully lift the speaker and all of the components in the speaker socket off of the monitor.
