Введение
Separate the case in order to remove casing holding the touchscreen in place. Replace the touchscreen.
Выберете то, что вам нужно
Use a J1 Phillips screwdriver to remove the four 6.1 mm screws at the back of the monitor.
In both pictures, disconnect the zero insertion force (ZIF) connector from the motherboard using your fingernail by sliding up on the male end of the connector to loosen it.
Еще один человек закончил это руководство.
3 Комментариев
would the steps be the same for the g755 screen?
Would steps be the same for the G755?
