Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
Ensure that wired connection between circuit board and back shell is not strained
Fold the back shell underneath the front shell and circuit board
Еще один человек закончил это руководство.
