Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The back speaker is where the ring of the phone comes from.
Выберете то, что вам нужно
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
Ensure that wired connection between circuit board and back shell is not strained
Fold the back shell underneath the front shell and circuit board
Lay the back shell with the inside facing up
To remove the speaker guard, first remove the 7mm screw from inside the back shell
To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
Gently push the speaker guard out of place with your thumb
Carefully slide the speaker out from its setting and place speaker guard aside
With speaker exposed, remove the speaker by cutting the red and black wires near their contact location
