Uninstalling an Electric Water Heater
Выберете то, что вам нужно
  1. Uninstalling an Electric Water Heater, Water Heater: шаг 1, изображение 1 из 1
    • At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
    • Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
  2. Uninstalling an Electric Water Heater: шаг 2, изображение 1 из 2 Uninstalling an Electric Water Heater: шаг 2, изображение 2 из 2
    • Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
    • Some electric water heater models may have only one access panel, located near the bottom of the tank. Some may have two— both an upper and lower access panel.
    • Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
    • Disconnect the wiring from the electrical components in the panel.
  3. Uninstalling an Electric Water Heater, Draining the tank: шаг 4, изображение 1 из 1
    • Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
    • Open the drain valve on the water heater by turning it counter-clockwise.
    • Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
    • If the water flow slows down, you can open a sink or tub faucet to help the tank drain quicker.
  4. Uninstalling an Electric Water Heater: шаг 5, изображение 1 из 1
    • Using adjustable pliers, disconnect the water lines from the tank.
    • If the lines are glued in place, you will need to use a steel wire saw to disconnect the water line.
  5. Uninstalling an Electric Water Heater: шаг 6, изображение 1 из 2 Uninstalling an Electric Water Heater: шаг 6, изображение 2 из 2
    • Using a pipe wrench, detach all remaining pipes from the tank.
  6. Uninstalling an Electric Water Heater: шаг 7, изображение 1 из 1
    • Remove the water tank.
    • The tank will have sediment and some water in it. It will be heavy and require at least 2 people to move it safely.
    • To install a new water heater, follow the manufacturer's installation instructions included with the new appliance.
Заключение
To install a new water heater, follow the manufacturer’s installation instructions provided with the new water heater.
2 человек успешно провели ремонт по этому руководству.
Lindsay Martin
Участник с: 09/20/17
178 Репутация
1 руководство автора
Команда
Pasco Hernando, Team S4-G11, Prince Winter 2017 Участник Pasco Hernando, Team S4-G11, Prince Winter 2017
PHSC-PRINCE-W17S4G11
1 член
Автор 1 руководств
1 Комментарий к руководству
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
Juliet Cyrus - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 16
За последние 30 дней: 63
За всё время: 6,205
