Выберете то, что вам нужно
Place the phone facedown on a cleared work area
Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
Grip the top right corner of the battery.
Remove the battery by pulling it outwards.
Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
Еще один человек закончил это руководство.
