Введение
This Guide is here to help you upgrade your Late 2008 2.0Ghz Aluminum Unibody Macbook to have a Backlit keyboard! (without buying an entire new topcase!) Keyboards can be purchased off ebay for less than $75.
Выберете то, что вам нужно
Remove the single Phillips screw securing the hard drive bracket to the chassis.
Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Remove the following three screws securing the fan to the upper case:
Two 5 mm Phillips screws.
One 7 mm Phillips screw.
Use a spudger to pry the fan connector straight up and out of its socket on the logic board.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Use a spudger to pry the optical drive connector straight up off the logic board.
Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
Peel back the small piece of black tape covering the right speaker cable.
Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
Lift the subwoofer and right speaker assembly out of the upper case.
Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
Pull the IR sensor ribbon cable straight away from the logic board.
Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
Pull the keyboard ribbon cable straight out of its socket.
Remove the two 5 mm Phillips screws securing the keyboard flex bracket to the upper case.
Lift the keyboard flex bracket out of the upper case.
Remove the single Phillips screw securing the battery cable cover to the upper case.
Remove the battery cable cover from the upper case.
Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
Disconnect the battery cable connector by pulling it straight away from the logic board.
Remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
Lift the bottom case clip out of the upper case.
Remove the following five screws securing the logic board to the upper case:
Four 3 mm Phillips screws.
One 3.5 mm Phillips screw.
Remove the two 7 mm Phillips screws securing the DC-in board to the upper case.
Lift the logic board from its left edge and pull it out of the upper case.
Remove the following screws securing the battery connector cover to the upper case:
One 2.5 mm Phillips screw.
Two 1.5 mm Phillips screws.
Lift the battery connector cover out of the upper case.
De-route the battery connector cable through the gap in the upper case and remove it from the computer.
Now that you have removed the display (only required if a new top case is used to replace the keyboard), logic board, optical drive, and various other components from the upper case (or top case) You should have something that looks like this!
We are ready to begin!
1st you'll notice the large black piece of plastic over the back of the keyboard.
you will need to use a spudger or a small straight edge screw driver to carefully unstick the the edges of the plastic from the upper case.
Be careful not to tear the plastic as it is very thin!
Now you will see a large clear plastic wafer stuck to the back of the keyboard.
You can remove this easily buy peeling it up slowly.
After you do this, remove the power button by pressing on the power button from the top of the upper case. The power button and a small metal ring (spring) will come out.
Now you have all probably noticed the horde of tiny black screws that cover the back of your keyboard... Yup! You guessed it! Time to take 'em out!
Now that you have removed all of the screws you can gently press on the face side of the keyboard and it will come right out. If you have removed ALL the screws!
Here is a pic of the top case without its keyboard! hope you're not winded yet! We're only half way there!
33 участников успешно повторили данное руководство.
16 Comments
The photos which show how to install the backlit aren't showing. Is there maybe another thread which shows them because I can't really figure it out .
The photos aren't failing to show up, there just aren't any photos - no one ever uploaded any, even though the text of the guide talks about the pictures. As you're doing the upgrade yourself though, snap some pictures, edit the steps here, and upload your pictures!
just a question. Where exactly do I put the backlight? Because I have a black film, then a thick plastic sheet, then the metal. then the silicon layer with the components inside, and then the front black sheet, and above that you mount the keys. In between which layer do I put the backlight?
Remove black film and put your backlit
I realize that this guide is getting a bit old, but I bought just the backlight part off Ebay. It's essentially a black film with couple of leds, a clear plastic sheet and a black matte layer. It goes on top (if you look at the MB from the bottom, as in this guide) the metal layer. So it replaces the parts you remove in steps 32 and 33, after which you can start reassembling.
