Введение
This guide will teach you how to replace a malfunctioning internal woofer of the Urge Basics Soundbrick portable speaker. This replacement can take place at anytime as long as there is plenty of light. To complete this repair, the you will need a Phillips #1 Screwdriver, the replacement woofers, and the Urge Basics Soundbrick.
Выберете то, что вам нужно
Flip the speaker upside down.
Unscrew the middle screw with a Philips #1 screwdriver.
Flip the speaker so that the ports are facing up.
Unfold the speaker's cover away from the body.
Remove the two Phillips #1 screws found on each side of the battery compartment.
Disconnect the battery connectors attached to the circuit board by unplugging them.
Disconnect the ribbon cable from the battery by carefully pulling it out.
Remove the battery compartment.
Remove the two Phillips #1 screws keeping each woofer in place.
Carefully remove the woofers and replace them with new ones.
Еще один человек закончил это руководство.
