Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the electrical tape from the wires and wire nuts.
Unscrew the wire nuts from the green and brown wires.
Use a ratchet wrench to remove both hex nuts on the bolts mounting the light to the bracket.
Use the ratchet wrench to remove the second set of hex nuts on the bolts from the light going through the mounting bracket.
Take the white ground wire off of the bolts going through the mounting bracket.
Place your thumbs on the bolts of the trailer light and push with even pressure on both bolts.
Remove the light and discard it.
Move to the driver side light on the trailer.
The process for removing the light on this side is the exact same it is for the light on the passenger side.
Follow steps 2-6 for removing the light from the driver side.
Inspect all the wiring on both sides of the trailer itself and closely look at points of contact where the wires could potentially rub and get damaged.
Insert the bolts of the passenger side light into the mounting bracket on the trailer.
Place a lock washer and a hex nut (included in kit) onto each bolt sticking through the mounting bracket.
Tighten each hex nut down with a ratchet wrench.
For installing the new light on the mounting bracket on the driver side, repeat steps 9 and 10.
Move back to the passenger side light.
Use a pair of wire strippers to strip the ends of the green and brown wire coming from the newly installed light.
Take the ends of both brown wires and twist them together. Do the same thing with both of the green wires.
Take a wire nut and screw it onto the brown twisted-together wires. Do the same thing for the green twisted-together wires.
Move to the driver side.
Follow steps 12 and 13 to connect the yellow wires to each other and the brown wires to each other.
Еще один человек закончил это руководство.
