Введение
This is a step-by-step procedure for replacing an E-cigarette coil that is placed in a tank. The tank holds the E-cigarette flavors (juice). The coil brand is Uwell Crown III and the coil ohms are 4.0 ohms.
Выберете то, что вам нужно
Take-off the upper lid. This is necessary as the lid will go through cleaning process.
Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil.
To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly.
After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step.
Place the new coil inside the tank. Make sure the coil is stable and not moving.
Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed.
To reassemble your device, follow step 2 in reverse order.
Еще один человек закончил это руководство.
