Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the tank from the E-cigarette by gently unscrewing it by hand.
Take-off the upper lid. This is necessary as the lid will go through cleaning process.
Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil.
This is the tank and both upper and bottom lids after the disassembly process.
To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly.
After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step.
Use the hair dryer with medium heat to make sure no water drops exist.
Place the new coil inside the tank. Make sure the coil is stable and not moving.
Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed.
Еще один человек закончил это руководство.
