VHS Shell Replacement
Выберете то, что вам нужно
  1. VHS Shell Replacement, Plastic Shell: шаг 1, изображение 1 из 2 VHS Shell Replacement, Plastic Shell: шаг 1, изображение 2 из 2
    • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
  2. VHS Shell Replacement: шаг 2, изображение 1 из 1
    • Once the screws are out, pull off the front of the VHS shell.
    • Take off any labels on the sides of tape before doing this step.
    • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
  3. VHS Shell Replacement: шаг 3, изображение 1 из 2 VHS Shell Replacement: шаг 3, изображение 2 из 2
    • Hold down on the white lever.
    • While holding down, carefully take out the reel on the right.
    • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
  4. VHS Shell Replacement: шаг 4, изображение 1 из 2 VHS Shell Replacement: шаг 4, изображение 2 из 2
    • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
    • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
  5. VHS Shell Replacement: шаг 5, изображение 1 из 1
    • Once the screws are out, pull off the front of the replacement shell.
  6. VHS Shell Replacement: шаг 6, изображение 1 из 1
    • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
    • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
  7. VHS Shell Replacement: шаг 7, изображение 1 из 1
    • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
  8. VHS Shell Replacement: шаг 8, изображение 1 из 1
    • Turn the reels to retract any excess tape hanging out of the top.
    • This isn't a necessary step, just one that I prefer to do.
  9. VHS Shell Replacement: шаг 9, изображение 1 из 1
    • Place the top of the replacement shell back on.
  10. VHS Shell Replacement: шаг 10, изображение 1 из 1
    • Screw the screws back in with a screwdriver.
Заключение
McKinley Hixon
Участник с: 03/19/21
202 Репутация
1 руководство автора
Команда
2 Комментарии к руководству
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - Ответить
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 23
За последние 30 дней: 100
За всё время: 2,993
