VTech InnoTab 2s Screen Replacement
Выберете то, что вам нужно
  1. VTech InnoTab 2s Screen Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Screen Replacement: шаг 2, изображение 1 из 2 VTech InnoTab 2s Screen Replacement: шаг 2, изображение 2 из 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Screen Replacement: шаг 3, изображение 1 из 3 VTech InnoTab 2s Screen Replacement: шаг 3, изображение 2 из 3 VTech InnoTab 2s Screen Replacement: шаг 3, изображение 3 из 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Screen Replacement: шаг 4, изображение 1 из 2 VTech InnoTab 2s Screen Replacement: шаг 4, изображение 2 из 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Screen Replacement: шаг 5, изображение 1 из 2 VTech InnoTab 2s Screen Replacement: шаг 5, изображение 2 из 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2s Screen Replacement, Motherboard: шаг 6, изображение 1 из 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2s Screen Replacement: шаг 7, изображение 1 из 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2s Screen Replacement: шаг 8, изображение 1 из 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2s Screen Replacement: шаг 9, изображение 1 из 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2s Screen Replacement: шаг 10, изображение 1 из 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2s Screen Replacement, Screen: шаг 11, изображение 1 из 2 VTech InnoTab 2s Screen Replacement, Screen: шаг 11, изображение 2 из 2
    • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
    • Remove the front panel from the device to expose the screen.
  12. VTech InnoTab 2s Screen Replacement: шаг 12, изображение 1 из 1
    • Using a heat gun, heat the glue that holds the screen to the rest of the device.
    • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
Заключение
Еще один человек закончил это руководство.
Esthevan Romeiro
Участник с: 10/06/16
261 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 5-1, Lacy Fall 2016 Участник USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 748
