Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite Only
Выберете то, что вам нужно
Using a plastic opening tool, gently pry off the circular plating over the camera lens.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
Еще один человек закончил это руководство.
