Введение
In order to repair or replace most parts of your VTech Kidizoom Camera Connect you'll need to be able to open the device. This guide gives step by step instructions on how to carefully open the main body of the Kidizoom Camera Connect and replace the front case.
Выберете то, что вам нужно
Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
Remove the two battery cartridges located on the underside of the camera.
Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
The device should now be open and ready for further repair and/or replacement parts.
Еще один человек закончил это руководство.
