Введение
Use this guide to remove and replace the button and circuit board used for taking photos
Выберете то, что вам нужно
Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
Remove the two battery cartridges located on the underside of the camera.
Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
The device should now be open and ready for further repair and/or replacement parts.
Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
Еще один человек закончил это руководство.
