Введение
If your Smartwatch is not charging, and you tested the cables, then the battery may need to be replaced. This guide will show you how to do this.
Выберете то, что вам нужно
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
Carefully pry the battery off of the circuit board using the plastic opening tool.
De-solder the wires connecting the battery to the circuit board.
Remove the battery.
4 Комментариев
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
