Введение
If one of the cameras on your device is broken, cracked, or damaged in any way, the following guide will show you how to replace the camera.
Выберете то, что вам нужно
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
Carefully lift the clips and slide the cameras out.
