Введение
If the speakers on your watch are not working, cracked, or damaged in anyway it will need to be replaced. The following guide will show you how.
Выберете то, что вам нужно
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
Carefully desolder the speaker from the board.
Be careful to not desolder the battery cable.
