Введение
If your wristband has visible damage, is worn, torn or broken the following guide will help you repair your problem.
Выберете то, что вам нужно
Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Один комментарий
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
