VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement
Выберете то, что вам нужно
  1. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Battery Housing: шаг 1, изображение 1 из 2 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Battery Housing: шаг 1, изображение 2 из 2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Speaker Housing: шаг 2, изображение 1 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Speaker Housing: шаг 2, изображение 2 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Speaker Housing: шаг 2, изображение 3 из 3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Red Ring: шаг 3, изображение 1 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Red Ring: шаг 3, изображение 2 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Red Ring: шаг 3, изображение 3 из 3
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  4. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement: шаг 4, изображение 1 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement: шаг 4, изображение 2 из 3 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement: шаг 4, изображение 3 из 3
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
  5. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Main Housing: шаг 5, изображение 1 из 2 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Main Housing: шаг 5, изображение 2 из 2
    • Unscrew the six 8 mm Phillips #0 screws at each of the points circled in red in the first image.
    • To open, separate the two sides of the housing. They should come apart fairly easily, however you may use a spudger to pry it open. Once it's apart, it should look like the second image.
  6. VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Volume Selector Switch: шаг 6, изображение 1 из 2 VTech Spin and Learn Color Flashlight Volume Selector Switch Replacement, Volume Selector Switch: шаг 6, изображение 2 из 2
    • Once the main housing is open, you will have to unscrew the 6 mm Phillips #0 screws from the motherboard to get to the volume selector.
    • The Volume Selector is located in the back of the motherboard and sits in the slot as indicated in the 2nd image.
Заключение
Tess Puhak
Участник с: 08/27/15
347 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 2-6, Blackwell Fall 2015 Участник USF Tampa, Team 2-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G6
3 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 290
