Введение
One common issue that many people have had in regards to their VTech baby phone was song looping, which may be a result of low battery charge. If replacing the batteries does not solve your problem, this guide will still get you started on replacing all the other items inside the device. The first thing you will need to do before replacing any of the parts in your VTech baby phone, is remove the batteries. For many common issues, simply replacing the batteries will fix the problem. If you need to replace the battery of your VTech Touch and Swipe Baby Phone follow this guide.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
Еще один человек закончил это руководство.
2 Комментариев
Seems this device is VERY sensitive to low batteries. An issue I assumed was the power switch (randomly turning off) was actually batteries. Also hilarious this has an iFixit page.
Thank you! Changing the batteries fixed the loop issue
