Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
One common issue that many people have had in regards to their VTech baby phone was song looping, which may be a result of low battery charge. If replacing the batteries does not solve your problem, this guide will still get you started on replacing all the other items inside the device.
Запчасти
Детали не указаны.
  1. Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise. Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise.
    • Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
    • Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  4. Take care when you want to close it. There is a notch. First you have to hook up that notch. Then firmly use a PH1 screwdriver to secure it.
    • Take care when you want to close it. There is a notch.
    • First you have to hook up that notch.
    • Then firmly use a PH1 screwdriver to secure it.
Заключение
Еще один человек закончил это руководство.
Zack Drawdy
Участник с: 04.09.2015
231 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-4, Sullivan Fall 2015 Участник USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 членов
Автор 6 руководств
Один комментарий
Seems this device is VERY sensitive to low batteries. An issue I assumed was the power switch (randomly turning off) was actually batteries. Also hilarious this has an iFixit page.
Chris Uthe - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 588
