Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will teach the user how to replace the fan.
Выберете то, что вам нужно
Flip the laptop over so that the Service Tag is shown at the top left corner.
Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
Locate the battery, located on the top side of the laptop to the right of the Service Tag .
Remove the battery by pressing inwards on the tabs on either side of the battery.
Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
Remove the connection by gently pull the remaining connection up from where it is attached.
Replace the old fan with the new one.
Another option to making it quieter it is to blow off the accumulated dust either by blowing on it, or more effectively by using an air hose.
Еще один человек закончил это руководство.
