Введение
If you are experiencing no crank on key turn, it is likely either a dead battery or worn out ignition switch. If the battery is charged, please disconnect, and try replacing the ignition switch with a new one.
This video will show you how to remove the steering wheel in order to gain access to the ignition switch housing.
Выберете то, что вам нужно
Видеоинструкции
Почти готово!
Заключение
0 Комментариев
