Введение
The Velocity Micro Cruz T301 is a tablet that is specifically designed as a multimedia device. The speaker is necessary for all audio based media. As such, it can be a vital part of the user’s experience.
This guide will show you the steps to remove the speaker on a tablet. Once the speaker is removed follow the guide in reverse to install a new speaker.
Выберете то, что вам нужно
Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
Use the opening tool to pry the back plate up.
Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
Move the spudger around the face to release the clips attached to the tablet base.
Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
