Velocity Micro Cruz T301 Speakers Replacement
Выберете то, что вам нужно
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: шаг 1, изображение 1 из 1
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: шаг 2, изображение 1 из 1
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: шаг 3, изображение 1 из 1
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: шаг 4, изображение 1 из 2 Velocity Micro Cruz T301 Speakers Replacement: шаг 4, изображение 2 из 2
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: шаг 5, изображение 1 из 1
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: шаг 6, изображение 1 из 1
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: шаг 7, изображение 1 из 1
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: шаг 8, изображение 1 из 1
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: шаг 9, изображение 1 из 1
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: шаг 10, изображение 1 из 1
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: шаг 11, изображение 1 из 1
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
Заключение
Ali Rashid Al Araimi
Участник с: 10/05/16
371 Репутация
Автор 3 руководств
Команду
USF Tampa, Team 1-6, Cagle Fall 2016 Участник USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 131
