Velocity NoteMagix M10 A82 Cooling Fan Replacement
Выберете то, что вам нужно
  1. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Battery: шаг 1, изображение 1 из 2 Velocity NoteMagix M10 A82 Cooling Fan Replacement, Battery: шаг 1, изображение 2 из 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 2, изображение 1 из 2 Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 2, изображение 2 из 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 5, изображение 1 из 1
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
  6. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Cooling Fan: шаг 6, изображение 1 из 1
    • Remove the eight 5.65mm Phillips #1 screws.
  7. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 7, изображение 1 из 2 Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 7, изображение 2 из 2
    • Place the computer open and with the screen facing up on the table.
    • Remove the three 3.65mm Phillips #1 screws in the right hand corner. Also remove the mirrored set of screws on the left side.
  8. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 8, изображение 1 из 1
    • Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
  9. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 9, изображение 1 из 1
    • Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
  10. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 10, изображение 1 из 2 Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 10, изображение 2 из 2
    • Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
  11. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 11, изображение 1 из 1
    • Remove the two 4.80mm Phillips #00 screws holding down the fan.
  12. Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 12, изображение 1 из 2 Velocity NoteMagix M10 A82 Cooling Fan Replacement: шаг 12, изображение 2 из 2
    • Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
Заключение
Jaymes Lee
Участник с: 08/17/12
101 Репутация
1 руководство автора
Команда
Cal Poly, Team 14-9, Forte Fall 2013 Участник Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 12
За всё время: 500
