Введение
This guide will show how to safely remove the hard drive from the NoteMagix M10 A82 netbook.
Выберете то, что вам нужно
Place the notebook on the table, with the battery facing away from you.
Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
Maintain holding the right switch in the "unlock" position.
Use your left hand to slide the left switch from "lock" to "unlock".
Maintain both left and right switches in the "unlock" position.
Use your forefingers to push the battery out of the computer.
Use the spudger to push the area above the connector on the hard drive to the right.
Lift the hard drive gently from the computer with the spudger.
