Verizon Ellipsis 7 Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: шаг 1, изображение 1 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: шаг 1, изображение 2 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: шаг 1, изображение 3 из 3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 2, изображение 1 из 2 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 3, изображение 1 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 3, изображение 2 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 3, изображение 3 из 3
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 4, изображение 1 из 2 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 4, изображение 2 из 2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Rear Facing Camera Replacement, Speaker: шаг 5, изображение 1 из 2 Verizon Ellipsis 7 Rear Facing Camera Replacement, Speaker: шаг 5, изображение 2 из 2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 6, изображение 1 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 6, изображение 2 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 6, изображение 3 из 3
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
  7. Verizon Ellipsis 7 Rear Facing Camera Replacement, Rear Facing Camera: шаг 7, изображение 1 из 1
    • Use the tweezers to carefully disconnect the power cable bundle from the motherboard.
  8. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 8, изображение 1 из 2 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 8, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the 10 screws from the motherboard.
    • The screws shown in the first picture are the more common 4.76 mm.
    • The screw shown in the second picture is shorter, 3.175 mm, than the rest of the screws
  9. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 9, изображение 1 из 2 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 9, изображение 2 из 2
    • Remove the 5 antenna cable connectors from the motherboard using a spudger.
  10. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 10, изображение 1 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 10, изображение 2 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 10, изображение 3 из 3
    • Disconnect the two ZIF connectors that are connected to the motherboard with a spudger. Lift up the metal part of the connector and then pull the connector off of its port
    • Once disconnected pull away from its connector carefully with tweezers.
    • Once the connectors have been disconnected you can gently lift up on the motherboard to remove it from the device.
  11. Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 11, изображение 1 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 11, изображение 2 из 3 Verizon Ellipsis 7 Rear Facing Camera Replacement: шаг 11, изображение 3 из 3
    • Remove the motherboard from the tablet.
    • Use the spudger to disconnect the press lift connector.
    • Carefully flip the motherboard over. Disconnect the camera at the top of the board using tweezers.
Заключение
Еще один человек закончил это руководство.
Charles Gorbett
Участник с: 10/10/16
242 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team 12-7, Blackburne Fall 2016 Участник Sam Houston State, Team 12-7, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G7
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 374
