Введение
This guide will show you how to replace a rear facing camera on a Verizon Ellipsis 7 correctly. This is vital in taking pictures from the back of your device. This guide will require extra precautions, as you are going to have to take out the main motherboard. Performing the actions in this guide incorrectly could break your device.
Выберете то, что вам нужно
Hold down the power button until the screen goes black to turn off the device.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in and pull it out after hearing a click.
Take off the back panel.
Pry open the back cover carefully with a plastic opening tool.
Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
Remove the charging (micro-USB) port.
Unscrew the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
Remove the charging port board from the phone using tweezers.
Place the replacement charging port into the phone.
Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
Using tweezers carefully lift the connector up to disconnect it from the motherboard.
Using tweezers carefully pull the speakers up and out of device.
Use the tweezers to carefully disconnect the power cable bundle from the motherboard.
Disconnect the two ZIF connectors that are connected to the motherboard with a spudger. Lift up the metal part of the connector and then pull the connector off of its port
Once disconnected pull away from its connector carefully with tweezers.
Once the connectors have been disconnected you can gently lift up on the motherboard to remove it from the device.
Remove the motherboard from the tablet.
Carefully flip the motherboard over. Disconnect the camera at the top of the board using tweezers.
Еще один человек закончил это руководство.
