Verizon Ellipsis 7 Speaker Replacement
Выберете то, что вам нужно
  1. Verizon Ellipsis 7 Speaker Replacement, Charging Port: шаг 1, изображение 1 из 3 Verizon Ellipsis 7 Speaker Replacement, Charging Port: шаг 1, изображение 2 из 3 Verizon Ellipsis 7 Speaker Replacement, Charging Port: шаг 1, изображение 3 из 3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Speaker Replacement: шаг 2, изображение 1 из 2 Verizon Ellipsis 7 Speaker Replacement: шаг 2, изображение 2 из 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Speaker Replacement: шаг 3, изображение 1 из 3 Verizon Ellipsis 7 Speaker Replacement: шаг 3, изображение 2 из 3 Verizon Ellipsis 7 Speaker Replacement: шаг 3, изображение 3 из 3
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Speaker Replacement: шаг 4, изображение 1 из 2 Verizon Ellipsis 7 Speaker Replacement: шаг 4, изображение 2 из 2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Speaker Replacement, Speaker: шаг 5, изображение 1 из 2 Verizon Ellipsis 7 Speaker Replacement, Speaker: шаг 5, изображение 2 из 2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Speaker Replacement: шаг 6, изображение 1 из 3 Verizon Ellipsis 7 Speaker Replacement: шаг 6, изображение 2 из 3 Verizon Ellipsis 7 Speaker Replacement: шаг 6, изображение 3 из 3
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
Заключение
2 участников успешно повторили данное руководство.
Charles Gorbett
Участник с: 10/10/16
242 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team 12-7, Blackburne Fall 2016 Участник Sam Houston State, Team 12-7, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G7
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 1,169
