Verizon Ellipsis 8 Battery Replacement
Выберете то, что вам нужно
  1. Verizon Ellipsis 8 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Battery Replacement: шаг 2, изображение 1 из 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Battery Replacement: шаг 3, изображение 1 из 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Battery Replacement: шаг 4, изображение 1 из 1
    • Lift and remove the battery from the device.
Заключение
7 участников успешно повторили данное руководство.
Jack
Участник с: 02/06/19
589 Репутация
Автор 3 руководств
Команда
UC Davis, Team S18-G6, Lore Winter 2019 Участник UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 членов
Автор 3 руководств
2 Комментариев
Thanks! Easy to follow because of the pictures.
Siegfried Harrison Ph.D. - Ответить
These instructions do not apply to the Verizon Ellipsis 8, QTASUN1. The G3 LTE unit requires that you remove the top end that covers the camera lens by popping the edge fasteners along the seam across the back with the spudger, carefully and then sliding the end (that covers the camera lens) off the top of the tablet. At that point three tiny Allen screws will become exposed. Remove the tiny screws and put them on a piece of tape! Make sure the micro memory card and sim card are removed! Using the spudger ( or a very thin knife edge) pop the bottom covering snaps backwards until you can slide the back downward to expose the battery. At that point it is the same as the description for battery replacement. Be very careful about loosing the three tiny, tiny, tainy flat head allen screws that hold the back on the tablet. Take your time and be methodical. If an 80 year old can do it, so can you!
James V Redding - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 37
За последние 30 дней: 181
За всё время: 8,179
