Введение
To replace the refresh button, you will need to open the router's outer casings. This replacement is simple and will not take much time to complete.
Выберете то, что вам нужно
Insert the plastic-opening tool under the silver labeled casing.
Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
