Введение
Make sure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
Выберете то, что вам нужно
Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
Then use the plastic opening tool to remove the motherboard from the front half of the phone.
Next you will peel off the keypad after the motherboard is removed.
Lastly insert the new keypad.
To reassemble your device follow these instructions in reverse order.
Еще один человек закончил это руководство.
