Выберете то, что вам нужно
Шаг 1 Prepare your phone
Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
Shut down your phone.
Set the phone down on a soft surface with space to store removed parts safely.
Unclip and remove the rear cover,
Remove any SIM/MicroSD cards.
Unscrew 12 black screws. A magnet is helpful for storing them. Try a fridge magnet face down.
Use a pick or your thumbnail around the display bezel to separate the frame from the phone.
Set aside the frame being careful not to lose the volume and power buttons.
Gently pry the battery plug up as shown.
Bend the cable up so the plug can't touch the board.
Unpick the white tabs from the top of the battery and pull gently and slowly as shown. Be careful not to snag the tapes. If both tapes come out cleanly the battery will be free. Hold the battery down with your other hand.
Insert new battery. You may wish to stick it down with the new white strips.
To reassemble your device, follow these instructions in reverse order. Make sure the two buttons are inserted in the frame the right way around when reassembling.
3 участников успешно повторили данное руководство.
