Viewsonic gTablet UPC300-2.2 Antenna Replacement
Выберете то, что вам нужно
  1. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Back Cover Screws: шаг 1, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Back Cover Screws: шаг 1, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Back Cover Screws: шаг 1, изображение 3 из 3
    • Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover.
    • Have patience! These are held in with glue and can take time and a few attempts to remove.
    • Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
  2. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Pry Off Back Cover: шаг 2, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Pry Off Back Cover: шаг 2, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Pry Off Back Cover: шаг 2, изображение 3 из 3
    • Using the flat end of your prying tool, work the back cover away from the rest of the gTabet.
    • Starting near the charging port, work in one direction around the perimeter of the device.
    • Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Lift off back cover to reveal the interior of the device.
  3. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Identify Battery & Prepare for Removal: шаг 3, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Identify Battery & Prepare for Removal: шаг 3, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Identify Battery & Prepare for Removal: шаг 3, изображение 3 из 3
    • The battery is the large black square that dominates much of the device interior.
    • There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
  4. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect Battery Power Cable: шаг 4, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect Battery Power Cable: шаг 4, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect Battery Power Cable: шаг 4, изображение 3 из 3
    • Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place.
    • The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
  5. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Move Front-Facing Camera & Remove Battery: шаг 5, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Move Front-Facing Camera & Remove Battery: шаг 5, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Move Front-Facing Camera & Remove Battery: шаг 5, изображение 3 из 3
    • Using tweezers, remove the protective foam backing arch from the front-facing camera.
    • Pull the camera out of its housing and move it aside.
    • Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Gently lift the battery up and away from the rest of the device and set it aside.
  6. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Speaker Assembly: шаг 6, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Speaker Assembly: шаг 6, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Speaker Assembly: шаг 6, изображение 3 из 3
    • Using tweezers or the spudger-wiggle technique, disconnect the two wires (shown here to the right of the battery power cable housing) from their housings.
    • It is very easy to damage the wires going to and from these connectors! Going slow and using as little force as possible will help to prevent this.
  7. Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Antenna: шаг 7, изображение 1 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Antenna: шаг 7, изображение 2 из 3 Viewsonic gTablet UPC300-2.2 Antenna Replacement, Disconnect the Antenna: шаг 7, изображение 3 из 3
    • Find the antenna receiver affixed to the LCD Screen chassis with foil tape. Gently peel back the foil tape and remove the antenna.
    • Now follow the wire attached to the antenna back to where it connects to the motherboard. Gently rotate and lift the connection until it lifts away.
    • You may now install a replacement antenna by reversing these steps.
Заключение
Еще один человек закончил это руководство.
Cristian
Участник с: 11/05/14
591 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 4-1, Miles Fall 2014 Участник UMass Dartmouth, Team 4-1, Miles Fall 2014
UMASSD-MILES-F14S4G1
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 210
