Visioneer OneTouch 7400 USB Belt Replacement
Выберете то, что вам нужно
  1. Visioneer OneTouch 7400 USB Belt Replacement, Outer Case: шаг 1, изображение 1 из 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Belt Replacement: шаг 2, изображение 1 из 2 Visioneer OneTouch 7400 USB Belt Replacement: шаг 2, изображение 2 из 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Belt Replacement: шаг 3, изображение 1 из 3 Visioneer OneTouch 7400 USB Belt Replacement: шаг 3, изображение 2 из 3 Visioneer OneTouch 7400 USB Belt Replacement: шаг 3, изображение 3 из 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Belt Replacement: шаг 4, изображение 1 из 1
    • Separate the two casement pieces.
  5. Visioneer OneTouch 7400 USB Belt Replacement, Belt: шаг 5, изображение 1 из 1
    • Remove the screw holding the tension spring in place.
  6. Visioneer OneTouch 7400 USB Belt Replacement: шаг 6, изображение 1 из 1
    • Use the plastic opening tool to lift up the tension spring.
    • Be careful. The spring will fly.
  7. Visioneer OneTouch 7400 USB Belt Replacement: шаг 7, изображение 1 из 1
    • Remove the belt from the spool.
    • The spool is a loose piece; don't lose it.
  8. Visioneer OneTouch 7400 USB Belt Replacement: шаг 8, изображение 1 из 1
    • Loosen the belt enough to turn over the sensor bar.
  9. Visioneer OneTouch 7400 USB Belt Replacement: шаг 9, изображение 1 из 2 Visioneer OneTouch 7400 USB Belt Replacement: шаг 9, изображение 2 из 2
    • With the sensor bar turned upside down, remove the screw in the middle of the bar.
    • Lift off the metal plate if it does not come away with the screw.
  10. Visioneer OneTouch 7400 USB Belt Replacement: шаг 10, изображение 1 из 1
    • Carefully lift the belt out of the groove in the sensor bar to remove.
Заключение
Jena
Участник с: 10/18/13
608 Репутация
Автор 6 руководств
Команда
University of Maine, Team 1-13, Diaz Fall 2013 Участник University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 членов
Автор 17 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 421
