Введение
Use this guide to remove and replace the Visioneer OneTouch 7400 USB scanner motor.
Выберете то, что вам нужно
Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
Remove the screw beneath the foot-pad.
Rotate the scanner so the screw hole is located on the top left hand side.
Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
Gently pry the two casements apart beginning above the screw hole and working your way around.
Carefully detach the wires from the motherboard, pulling slowly but firmly.
