Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Using the spudger, create a small opening to be used to open the back case.
While holding the case open, insert the plastic opening tool to get a larger opening.
Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
Gently remove the speakers from the back case with tweezers and set the case aside.
Один комментарий
Ok but where to I go to buy the replacement for the screen? This is directing us to take apart and reassemble the tablet, but not where to buy or get a new screen.
