Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Using the spudger, create a small opening to be used to open the back case.
While holding the case open, insert the plastic opening tool to get a larger opening.
Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
Gently remove the speakers from the back case with tweezers and set the case aside.
insert the spudger and gently work around and underneath the battery.
With the battery separated from the LCD Display, set it aside.
Desolder and remove the 2 wires from the motherboard.
go to Amazon and order a Prestige Prime 10SE tablet
go to Amazon and order an Prestige Prime 10SE tablet
your tutorial worked but my tablet is a little different but it has the same model id
8 участников успешно повторили данное руководство.
7 Комментариев
Wat if the charge port how do u replace it Visaul land 10.1
Thank you for posting. Great illustrations. Got mine apart so easy.
where can I get a replacement battery for Visual Land Prestige 10D tablet?
Where can I get a replacement battery for Visual Land Prestige 10.1 tablet???
Thank you.
Belinda Rivera
brp52@hotmail.com
where can I get a replacement battery for visionland prestige 10 3.7v
My power button is not working at all, seems to be stuck/pushed in. How do I fix this? Only way for me to turn it on is to connect it to the charger cord.
