Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Using the spudger, create a small opening to be used to open the back case.
While holding the case open, insert the plastic opening tool to get a larger opening.
Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
Gently remove the speakers from the back case with tweezers and set the case aside.
insert the spudger and gently work around and underneath the battery.
With the battery separated from the LCD Display, set it aside.
Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
Gently grip and pull up the front camera, covered by protective adhesive foam.
Set aside the Camera housing.
Locate the LCD Connector.
Using tweezers, grip the small black tab connected to the white plastic.
Gently lift the tab towards you until it clicks.
Remove the connector by pulling straight out, gripping the black connector head.
Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
Lift the tab towards you until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head.
Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
Gently lift up on the controller and leave it hanging loose.
Remove screws located on motherboard.
Place on magnetic mat and label them
Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
6 участников успешно повторили данное руководство.
Один комментарий
I just received my tablet. and it will not allow me to set up a password. It keeps asking for previous password. I have done a hard reset but have not been able to set up my tablet.
