Введение
If your camera is not working, you may need to replace it completely. Following this guide will allow you to do so.
Выберете то, что вам нужно
Remove the two 8mm Phillips Head screws located at the bottom of your device.
Insert the spudger between the two pieces of the case around the media ports and pry them apart.
Finish unsnapping each plastic piece holding the device together along the bottom.
Move the spudger down the rest of the case, separating each side, and finally the top.
Pull the back off and place it to the side.
Unclip the connector that attaches the camera to the motherboard.
Gently pop the camera out of the connector and off the case.
Еще один человек закончил это руководство.
