Введение
This guide demonstrates the proper way to remove the cameras in order to reconnect or replace them. This requires no soldering or screws.
Выберете то, что вам нужно
Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
Move tool around each connection, and continue around the device until all connections have been loosened.
Once all connections have been loosened and using a soft surface, place the device onto its screen.
Maneuver the hook tweezers to flip up the black hinged ZIF connector to disconnect camera module.
After ZIF connector is flipped up, the camera module may be removed.
