Введение
This guide will show you how to remove your device's motherboard.
Выберете то, что вам нужно
With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
