Введение
The Vivo X7 Plus is hard to open and has a single unit display, but is moderately repairable due to its accessible battery. The phone ultimately earns a 7 out of 10 on the repairability scale.
Запчасти
Детали не указаны.
  1. Vivo X7 Plus Repairability Assessment, Vivo X7 Plus Repairability Assessment: step 1, image 1 of 3 Vivo X7 Plus Repairability Assessment, Vivo X7 Plus Repairability Assessment: step 1, image 2 of 3 Vivo X7 Plus Repairability Assessment, Vivo X7 Plus Repairability Assessment: step 1, image 3 of 3
    • Reference photos.
  2. Vivo X7 Plus Repairability Assessment: step 2, image 1 of 3 Vivo X7 Plus Repairability Assessment: step 2, image 2 of 3 Vivo X7 Plus Repairability Assessment: step 2, image 3 of 3
    • T2 screws on the bottom, but tough clips secure the case, making the screws superfluous.
    • Tough prying procedure is made slightly simpler by the larger form factor, more space between clips and more flexibility.
    • Interior reference.
  3. Vivo X7 Plus Repairability Assessment: step 3, image 1 of 1
    • Battery is readily accessible and pull tabs make removal easy.
    • Instructions are somewhat ambiguous, but it's hard to mess it up.
  4. Vivo X7 Plus Repairability Assessment: step 4, image 1 of 2 Vivo X7 Plus Repairability Assessment: step 4, image 2 of 2
    • Removal of the speaker/antenna assembly is immediately possible.
    • The next layer of components out are: Interconnect cable, antenna interconnect cable, button cable, brackets, SIM eject lever, and front facing camera.
  5. Vivo X7 Plus Repairability Assessment: step 5, image 1 of 2 Vivo X7 Plus Repairability Assessment: step 5, image 2 of 2
    • Interconnect cable attached to the rear of the daughterboard is annoying.
    • Removal of daughterboard and interconnect cable.
    • The daughterboard is relatively bare, but two high-wear mechanical parts make repair more expensive for either headphone jack or charging port replacement.
  6. Vivo X7 Plus Repairability Assessment: step 6, image 1 of 2 Vivo X7 Plus Repairability Assessment: step 6, image 2 of 2
    • Next removable components are the home button bracket, followed by home button.
    • The only upper component immediately removable is the vibrator bracket.
    • But not the vibrator, which is trapped under the motherboard.
  7. Vivo X7 Plus Repairability Assessment: step 7, image 1 of 3 Vivo X7 Plus Repairability Assessment: step 7, image 2 of 3 Vivo X7 Plus Repairability Assessment: step 7, image 3 of 3
    • Motherboard is next to come out.
    • Once the motherboard is removed, the rear-facing camera can be removed. Also the rubber bumper on the flash/proximity sensor portion of the main board.
    • The final components off of the display assembly are the vibrator and speaker.
    • Last-out display that is fused and mounted to a frame means a cracked screen is a time-consuming, expensive repair.
  8. Vivo X7 Plus Repairability Assessment: step 8, image 1 of 2 Vivo X7 Plus Repairability Assessment: step 8, image 2 of 2
    • The Vivo X7 Plus earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery is fairly easily accessible and removable.
    • Parts could be more modular, especially mechanical/high wear components.
    • The opening procedure is very tough, but easier than on the smaller model.
    • The single unit display assembly is annoying to reach, and will be a costly part.
    • Manufacturer does not provide user-accessible repair documentation.
Финишная черта
9 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
453 904 Репутация
Автор 548 руководств
iFixit Участник iFixit
Community
146 членов
Автор 16 130 руководств
One Comment
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 46
За всё время: 4,001
