Введение
This replacement guide will help users that are having trouble with broken speakers to remove the speakers in a Vizio CT15.
Выберете то, что вам нужно
Turn the laptop off and remove all power cables.
Remove the six Phillips #0 screws.
Pull the back cover off.
Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
Use the flat end of a spudger to lift up the black tab on the ZIF connector.
Pull the ribbon cables out of the ZIF connector.
Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
