Vizio VTAB1008 Battery Replacement
Выберете то, что вам нужно
  1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: шаг 1, изображение 1 из 2 Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: шаг 1, изображение 2 из 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Battery Replacement: шаг 2, изображение 1 из 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Battery Replacement, Battery: шаг 3, изображение 1 из 3 Vizio VTAB1008 Battery Replacement, Battery: шаг 3, изображение 2 из 3 Vizio VTAB1008 Battery Replacement, Battery: шаг 3, изображение 3 из 3
    • Remove the ribbon strip that crosses the battery from both ends.
    • A blue opening tool may be used to assist.
  4. Vizio VTAB1008 Battery Replacement: шаг 4, изображение 1 из 2 Vizio VTAB1008 Battery Replacement: шаг 4, изображение 2 из 2
    • Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
    • This is the connector with the wires leading to the battery.
    • Tweezers may help.
  5. Vizio VTAB1008 Battery Replacement: шаг 5, изображение 1 из 3 Vizio VTAB1008 Battery Replacement: шаг 5, изображение 2 из 3 Vizio VTAB1008 Battery Replacement: шаг 5, изображение 3 из 3
    • Pull the battery away from the back panel.
    • A metal spudger may be needed to pry the battery from the backing.
    • The battery is glued to the back panel and caution should be used as to not break or rupture the battery pack.
Заключение
Еще один человек закончил это руководство.
Gilberto Ambriz
Участник с: 09/29/16
546 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 1-1, Crane Fall 2016 Участник Eastern Washington University, Team 1-1, Crane Fall 2016
EWU-CRANE-F16S1G1
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 1,335
