Vizio VTAB1008 Charging Port Replacement
Выберете то, что вам нужно
  1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: шаг 1, изображение 1 из 2 Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: шаг 1, изображение 2 из 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Charging Port Replacement: шаг 2, изображение 1 из 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Charging Port Replacement, Charging Port: шаг 3, изображение 1 из 3 Vizio VTAB1008 Charging Port Replacement, Charging Port: шаг 3, изображение 2 из 3 Vizio VTAB1008 Charging Port Replacement, Charging Port: шаг 3, изображение 3 из 3
    • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
    • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
  4. Vizio VTAB1008 Charging Port Replacement: шаг 4, изображение 1 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 4, изображение 2 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 4, изображение 3 из 3
    • Remove both antenna connectors with a blue opening tool/tweezers.
  5. Vizio VTAB1008 Charging Port Replacement: шаг 5, изображение 1 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 5, изображение 2 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 5, изображение 3 из 3
    • Remove the ribbon connector at the top of the motherboard using the opening tool.
  6. Vizio VTAB1008 Charging Port Replacement: шаг 6, изображение 1 из 2 Vizio VTAB1008 Charging Port Replacement: шаг 6, изображение 2 из 2
    • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
  7. Vizio VTAB1008 Charging Port Replacement: шаг 7, изображение 1 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 7, изображение 2 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 7, изображение 3 из 3
    • Remove the connector at the side of the motherboard using the opening tool.
    • The connector is covered by a piece of black tape.
  8. Vizio VTAB1008 Charging Port Replacement: шаг 8, изображение 1 из 2 Vizio VTAB1008 Charging Port Replacement: шаг 8, изображение 2 из 2
    • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
  9. Vizio VTAB1008 Charging Port Replacement: шаг 9, изображение 1 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 9, изображение 2 из 3 Vizio VTAB1008 Charging Port Replacement: шаг 9, изображение 3 из 3
    • Flip the motherboard over.
    • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
Заключение
Еще один человек закончил это руководство.
Gilberto Ambriz
Участник с: 09/29/16
546 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 1-1, Crane Fall 2016 Участник Eastern Washington University, Team 1-1, Crane Fall 2016
EWU-CRANE-F16S1G1
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 1,237
