Введение
Hello! This is a guide on how to replace the charging port in your Vizio VTAB1008!
Выберете то, что вам нужно
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Look into the tablet for loose connectors.
Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
Remove the ribbon connector at the top of the motherboard using the opening tool.
Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
Remove the red and black wire connector from the motherboard using either fingers or tweezers.
Flip the motherboard over.
Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
Еще один человек закончил это руководство.
